What he said. On my 2019 mod SIDs there's a grub screw holding the cable. I just put the top cap back on for aesthetics. In 18 months I'd locked the forks once, just to see. I don't miss it.which damper unit does it have? leave it unlocked & unscrew the cable & remove the screw & take off the top cap...what th top cap threads onto will reveal answer, i had an old unit, which i was able to remove & put a compression knob on which thumb remote
But also what he said. In my case the default setting is open.Although not a hard & fast rule, generally dampers for remote actuation have a return spring to allow the unit to default to its "relaxed" state, which depending on generation may be either open or locked. Non-remote dampers lack this spring to enable the damper to stay where you want it.....
