Roadie replacement rear hub advice
John U
MTB Precision
Howdy Burners,
After a few weeks of fucking around buying various fucking tools and parts from all over the country and the planet, I snapped the final fucking piece, the Park Tool RP-1, the moment it arrived trying to go through this service
for the wheels on this bike
The freehub design is a bit fucked and the bearing on the centreside of the freehub is surprisingly munted. The tools and parts required where hard to track down. Along the was I decided to take a short cut and purchased a complete freehub body and that fucking thing didn't fit because 12mm axel. The Park Tools pliers snapping was the last straw.
I'm now after a new hub, something that requires infrequent servicing, but when it does I won't need a bunch of hard to find specialist tools which break when you look at them, and is relatively easy to service. I'm guessing I'll need to get a new wheel built if I go down this path as nothing is likely to fit the fancy fucking set up on the bike.
Front wheel is fine. I hit the rough footbridges on the eastlink trail with a bit of pace if I'm carrying any. I don't think this has been too kind to the freehub, but in saying that the wheels still spin nicely and have remained true.
If I go down the hub route it needs to be 142x12mm, 6-Bolt, compatible with 11 speed.
All recommendations on what to get or next steps would be great. Any help appreciated. I'm too old to give any fucks about bling anymore.
I would agree with @Oddjob, I am running 3 sets of DT hubs (two 350s and one 240) and I rate them.
I run the 18 tooth ratchet on the road bike which is nice and quiet so can have a chat while riding.
You do need a special tool to remove the ratchet ring to replace the drive side hub bearing and the genuine item is not cheap. There are AliExpress copies but not sure if they are up to the task or not (haven't tried them out), it can require quite a bit of force to break it free. Any good shop should have one though...
Otherwise, they are dead easy to service. Ratchet clean and re-grease is all of 5min and you don't even need to remove the cassette.
If you want something low-maintenance and reliable, I’d look at hubs from Shimano or DT Swiss. Shimano’s Deore or SLX hubs are pretty solid, easy to service, and don’t need weird specialty tools. DT Swiss hubs use star ratchets and are known for being durable and fairly easy to work on too.
So I went down the DT350 route. Brand spanking new wheels collected to today.
Requested that they be built to match the Cube posted above. Fitting thinks up tonight and there doesn't appear to be enough room for the final/smallest cog on my 11 speed cassette. What am I doing wrong?
Test fitted the cassette on the old wheel. Went on no dramas. Cleaned all the facing surfaces on the cassette and tried to fit the DT 350 again. No luck.
Hub with cassette fitted, without the smallest cog.
Bits that I'm unable to attach
New hub free-wheel. Not sure why it looks so rough in the pic. It's new with a bit of Park grease on it.
Do I have the wrong free-wheel body? I checked before I left the shop and the fella confirmed it's compatibility with 11 speed.
Nice looking wheels otherwise.
Any help greatly appreciated.
Glad you got it sorted. Just so we know what the issue was, did they put the wrong freehub body on?
The shop said that they checked a couple of the DT 350 hubs that they had in store still in boxes and that some boxes labelled 11 speed road had 10 speed road freehub bodies fitted. So right box, incorrect contents. They're contacting the DT distributor to see what the story is.
The shop is shipping me an 11 speed freehub body with a return bag to send the 10 speed back. They were very good about it.
Until I saw the pic posted by OldCorollas I didn't realise that it was common practice to label 11 speed road freehub bodies '11 speed road'. My old wheel feehub was labelled like this. I would have known straight away in the shop yesterday when I was picking up the wheels if was clued up.
Pic from wheelbuilder.com
there's another comment on that page that caught my eye.. (may not be relevant)
"NOTE: Straight pull MTB hubs cannot be converted for use with 11 speed road cassettes. Cassette will touch flange."
Went for standard spokes for greater ease in finding replacements. Looks like that has already paid off.
