Solo has nothing to do with it. The negative spring, whether it's a self-equalised solo air, a fully separate chamber (dual air) or a coil only serves to give the very top stroke a bit of a push. Once you get a short way into the stroke the negative is basically pulled into a vacuum, or if a coil, simply just being a few extra grams of dead weight. Tokens give the fork better tuneability for a wide range of riders, in a way that just throwing air at it can't do, because they alter the compression ratio of the whole stroke..... they're only required because of this solo air BS.
Might just convert them to dual air...
Sadly no Duckmeister. The ability to change the ratio between the positive and negative piston (as well as the relative volumes using different length air piston rods) provides a level of tune ability that you can never really achieve with solo air and any number of tokens. The crappiness of solo air is what led to the development of various band-aid solutions like volume modifying piston heads (luftcappe, debonair etc.) and the dynamic volume reducers (MRP).Solo has nothing to do with it. The negative spring, whether it's a self-equalised solo air, a fully separate chamber (dual air) or a coil only serves to give the very top stroke a bit of a push. Once you get a short way into the stroke the negative is basically pulled into a vacuum, or if a coil, simply just being a few extra grams of dead weight. Tokens give the fork better tuneability for a wide range of riders, in a way that just throwing air at it can't do, because they alter the compression ratio of the whole stroke.
