Any idea how long they take to deliver?Offsetbushings.com | The finest MTB shock bushings | Offset & Standard
Offset and Standard Shock bushings for all full suspension bikes. Recommended by MBR / MBUK / Pinkbike. Easy ordering, shipped worldwide. Produced for Fox, RockShox, Cane Creek & many more.www.offsetbushings.com
I think it was around a week and a half, 2 weeks. Pretty quick in the current climate.Any idea how long they take to deliver?
I may have some 8x20mm aluminium "pins" that came on a shock I bought. They are for the igus type bushes.Looking to get some 8x20mm hardware for a Super Deluxe I bought recently.
Hard to find any Rockshox hardware in stock in Aus. and OS sellers wont post.
Can I just use same size hardware from a different manufacturer?
Sounds promising. Just the pin or the spacers as well?I may have some 8x20mm aluminium "pins" that came on a shock I bought. They are for the igus type bushes.
Ordered a set of hardware from these guys.I think it was around a week and a half, 2 weeks. Pretty quick in the current climate.
Could've gone with these guys too but I wanted some non-flanged polymer DU bushings and Cyclinic didn't appear have any...Hit up NS Dynamics in Brissy, they can machine hardware if needed, but I’d imagine standard RS hardware should be readily available.
Mounting Hardware (Single Eyelet)
Mounting hardware to suit Ohlins, Cane Creek, DVO, Fox, Rockshox, Marzocchi, and more. Hardware is for one end of shock only, if you have a shock with an eyelet on both ends you will need to order two ends of hardware.nsdynamics.com.au
