Z
Zaf
Guest
STOP LIKING THINGS THAT I DON'T LIKE!!!
Fixed that post for you. I'm gonna go squeeze my XTR's for a little while.
If you've got a set of XTs, take the contact point adjustment screw right out and tell us what you see in there.
You seem to have way too much time on your hands dude ;-)
Are you bed-ridden or something......
XT & SLX are pretty much the same.......google it.
I've read so much negative about Avid & so much positive about Shimano.
I have Shimano & love it. Would highly recommend.
Cheers, Daisy
I've disassembled M785s to see how it works. IIRC The screw sits against a hinged plastic part that pushes on the back of the master cylinder.
It does work (as in it does what it's designed to do). It's just naff at how effectively it works.
Interesting. With mine the screw position was making absolutely no difference to the contact point and when I took it out there appeared to be nothing behind it - meaning that it was a scam. Eventually the frustration with this lack of adjustment and always having the levers with wildly different amounts of throw (no matter how I bled them) is what me go back to Sram brakes.
The XT is excellent value for money. For ~$100/end you can't find a better brake. You can save a few bucks and get similar rest from the slx, but the XT reservoir cap is significantly series. *snip*
So if you can find them...buy them. Otherwise save some coin and buy the slx brakes.
*snip*
Just did a survey of my garage (way too much effort, seriously you must have too much time on your hands):
Shimano Saint
Shimano SLX (was running Formula but bike is for sale so back to SLX)
Hope Mono Mini Pro
Hope V4
Formula Oro Bianco
Formula R1
Avid V-brakes
I use Shimano because they just work and they're easy to work on, on the rare times that you have to change hoses or levers. I've only had to bleed a set once out of the 4 sets I've had in the last 10ish years. Much less fuss than dot fluid.
At the moment I'm running old Saint M800 (didn't even make the list!) with Straitline levers on the dually and XT M8000 on the hardtail.
The difference between the 2 sets is pretty significant! The Saints just won't die so I've had no need to replace them.... Also running 8 inch rotors front and rear on both bikes.
Currently got guide rsc's and they were awesome but now they are slowly shitting themselfs and are just getting me by. The guide ultimates have apparently fixed the issues with the other models.
If you're after results for gravity brakes this is what people run at Whistler
I've got Formula RO's that I absolutely love and have had zero issues. Plenty of power and excellent modulation.
Guide RS on the Povo Rune have been problem free as well and also have good power and feel. Used to have Zee's but they were not so good. Lever pump issues and pad contamination through leaking seals I suspect.
Have run Elixir 5 without issue also.
How do the M8000 compare? From what I've been reading they're not quite as trouble free as their predecesser (M785).
They have been replaced by the M8000, yea? So I'm assuming, its a matter of only finding a secondhand set of M785s now.
Haven't had much luck finding a complete set online anywhere.
You mean like this?
https://www.merlincycles.com/shiman...9LWW--lGzxkIeJH3SnEjoW9_g6tdFDLK2EaArLo8P8HAQ
You don't mind a black/silver combo? If so:
http://www.chainreactioncycles.com/...LUXdGxvF7Nc9jKAQq_Av4aAj098P8HAQ&gclsrc=aw.ds
http://www.cellbikes.com.au/Shimano...G4pZ34BrUV4emVfeyyFT2zdpQb1voDo2qQaAlKR8P8HAQ
http://www.ebay.com.au/itm/like/121...5960-0%26rvr_id%3D1081487220958&ul_noapp=true
Seems they are out there, but getting scarce.
The reason I tend to go with XTs is that they come with fined metallic pads which the SLX don't tend to.
You're gonna have to start putting a trigger warning on these posts so the Shimano haters stop "sour grapes'ing" about your superior brake choices.Those ones from merlin still work out to be a black silver combo.
I was recently trying to find a pair of same colour ones and couldn't.
Ended up getting the SLX 675 ones from Evans cycles for $128 for the set. Bargin, and I am very happy with them.
Previously had Elixer 5s and sick of the cost of getting them bled by LBS. Shimano I can do myself so they will basically pay for themselves in 12 months.
