RS coil Pikes U-turn winding down on it's own
hiredassassin
Hey folks.
Had this problem for a while, it stopped, but I just serviced the fork and now it's back again.
basically the U-turn adjuster keeps winding down on it's own as I ride - I go out for a ride with full 140mm travel, then an hour later when I stop, it's down to 110mm or something.
Has anyone else experienced this and found a way to stop it?
cheers.
mudmav
When you took apart the u turn knob and the cap under it there were three detent springs and ball bearings you need to refit the springs into the top cap leaving a gap between each spring and then sit the 3 ball bearings on top of the springs. These parts stop the u turn winding down as you descirbe.
Any problems pm me
Live2DieTrying
Happened to me once. I just tightened up the screw in the u-turn top cap until it was quite tight to turn, and has been fine ever since.
hiredassassin
All three springs and ball-bearings are in the right spot and the u-turn knob is bolted down as tight as possible but I'm still getting the same issue - hit any decent bump and it winds down about 1/3 of a turn.
I've even tried stretching the springs so they're a bit longer - no luck!
any other suggestions?
Live2DieTrying
Maybe the foot bolt at the bottom of your fork is a bit loose, allowing the spring to twist and wind down when compressed. You could need a new crush washer for it.
