here is the spec list this should help alot more. silly of me not to put it up in the first place
scott spec list
Frame Construction TIG-welded
Frame Tubing Material 6061 Alloy
Fork: Brand & Model Marzocchi DJ 1 SL, 100mm travel
Fork: Material Single
Rear: Shock Not applicable
Brakeset: Avid Juicy 3.5 hydraulic w/160mm rotor brakes, Avid Juicy 3.5 hydraulic levers
Shift Levers: SRAM X.7
Front Derailleur: E Thirteen LG1, ICSG05
Rear Derailleur: SRAM X.9
Crankset: TruVativ Holzfeller DH 1.1, 36 teeth
Pedals: TruVativ Hussefelt
Bottom Bracket: TruVativ Howitzer
Rear Cogs: 9-speed, 12 - 26 teeth
Chain: SRAM PG-971
Seatpost: Scott Pivotal zero offset, 31.6mm diameter
Saddle: Scott Pivotal ATMOSF AIR
Handlebar: Scott Pilot FR 2.0
Handlebar Stem: TruVativ Hussefelt
Headset: 1 1/8" threadless FSA Mallet
Hubs Front: Scott Pro, 20mm, Rear: Sun Ringle Lawwill 12mm Axle
Rims: Sun MTX 33, 32-hole
Tires: 26 x 2.25" Schwalbe Table Top Sport
Spoke: Brand DT Swiss Champion stainless, 15ga. (1.8mm) straight gauge
giant spec list
size: regular:13.5, large:14.5
colours: White
frame: ALUXX alloy: double butted, integrated gusset w/CNC BB yoke
fork: Rockshox Argyle 409 Air w/maxle 4"/100mm
rear derailleur: SRAM X-7 9 speed medium cage
front derailleur: N/A
shifters: SRAM X-5 trigger shift 9 speed
crankset: Raceface Diablous X-Type 36T
bottom bracket: Raceface Diablous X-Type integrated, outboard
shift/chain guide: E-13 STS Chain Guide
chain: Shimano HG73 9speed
cassette: SRAM PG950 11-32T
brakes: Avid Juicy 3 hydraulic w/6" rotors
brake: levers Avid Juicy 3 hydraulic
hubs Fr: Formula 20mm | Rr: Shimano Deore 9sp cassette disc
rims: Sun Rhyno Lite XL 26 x 36H w/eyelets
spokes: DT Swiss 14G stainless
tyres: Maxxis Holly Roller 2.4"
pedals: Truvativ Holzfeller
h.bar/stem: Truvativ Holzfeller
seat post: SDG I Beam 30.9 freestyle
saddle: SDG I Sky freestyle
grips: Giant lock-on
