My rear mech just starting playing up today , when the clutch is on the lower chain just goes all sloppy and has no tension - if I turn the clutch off the tension is ok again , aside from the clutch / tension issue the mech is working / shifting fine .
Anyone got any ideas ? I've googled how to adjust the clutch - but not sure if that's the problem or it means the clutch mech is probably just stuffed etc or something else needs doing ?
It doesn't seem to have done a huge of hours .
Thanks in advance if you have any ideas or advice , might save scrolling through a ton of threads on unrelated mech problems .
Cheers
Cheers
