You have simple dreams me thinks
@DMan
I am working with the Secus slowly to realise it’s potential. The set-and-forget days are behind me now. Once I get the settings dialled it will be simpler.
You will notice the initial sensitivity is really good. I thought my headset was loose when rocking the bike with the front brake on, but it was beautiful fork movement. So supple.
The nicest part I have found is the brake dive is reduced significantly. Mid stroke support is probably the highlight for me so far. Steve suggests 20% more pressure but I found that too harsh. I am just above my original, non-Secus 4 bar. 4.2-4.3. (FU freedom units!)
My first run at pace with less pressure had a small gap down to a tight berm. I can confirm that the bump stops are pretty good too.
TLDR worth it if weight is your hang up.
