yes.......hey guys, i have Marzocchi 2007 DJ4 forks, i tightened them up as tight i could to make them harder but they are still pretty soft.
dont get angry, but i think you can put air in the bottom of them but i dont want to do it because i may stuff it up any tips?
He might be worried about how to increase the pressure eg what kind of pump or putting too higher pressure in etc. DO NOT USE AN AIR COMPRESSOR!Since when does increasing air volume damage your forks? What else are you doing to "harden" them up?
Are you talking from experience Kris?He might be worried about how to increase the pressure eg what kind of pump or putting too higher pressure in etc. DO NOT USE AN AIR COMPRESSOR!
Should just be able to buy the spring separate?i'm assuming changing the springs and getting a rebuild/seal kit for it would make it a bit stiffer if done correctly. i'm aware of new seal kits for around 50 but dunno about the new springs though.
this would be a cheaper option than having to buy new forks.
correct me if i'm wrong.
