jeremy_2640
Item: 2014 Fox Float CTD Factory Series Rear Shock 8.5 x 2.5 Kashima
Item Condition: Near new (great condition)
Reason for selling: Not required
Price and price conditions: $380 ONO RRP $659
Extra Info: Will fit Yeti-SB66
Pictures:
2014 Fox's Float rear shocks feature their CTD dampening system for easy compression adjustments to suit the trail ahead. The CTD, Climb-Trail-Descend, dampening cartridge gives riders the option of three dampening platforms with simple adjustment (see below).
Climb: When in Climb mode the fork's low-speed compression dampening is set to its firmest setting, maximising pedal efficiency by reducing the amount the fork compresses due to rider input. This firm compression setting features a "blow off" whereby under a significant amount of force from the trail, such as a square edge impact or jumps/drops in the trail, the fork breaks through the platform and compresses accordingly.
Trail: When in Trail mode the fork's low-speed compression dampening setting is firm yet active to provide improved pedal efficiency and control over variable terrain. In the CTD Trail Adjust model this low-speed dampening compression setting is able to be adjusted into 3 preset levels, high/medium/low, to provide further control.
Descend: When in Descend mode the fork's low speed compression dampening setting is optimised for the perfect balance of control and plushness for steep, aggressive descents.
The Float air spring cartridge used in the Float CTD provides a progressive spring feel while allowing for infinite adjustment.
Pictures:
