Either that or they aren't pumped up, I should probably go stick the pump on them.The question is the travel...there was never a 60mm Reba fork.
Likely there's a leak somewhere, positive into negative chamber that's sucking the travel down :-(
Yep, did that and this is the result.Let the air out of the negative, pump up the positive and see if that pulls them back up.
