Item: Specialized P.26 Pro, size long (22.25" top tube)
Location: Adelaide. Can post Australia wide at buyers expense, most likely between $50-80 depending on location.
Item Condition: Barely used, still has original tyres. Minimal marks (pictured) for a dirt jump bike. Was used once in the last year or so (literally). Forks were serviced by NSDynamics only been ridden on once since then and the bike has been sitting in the shed ever since.
Reason for selling: Don't use and need the room.
Price and price conditions: $OLD
Extra Info:
Specs are:
All stock with Specialized P.Series components, with a few parts changed being the following below.
Message me if you would like more info or photos, thanks.
Pictures:
Extra Info:
Specs are:
- Renthal Fatbar Lite 750mm wide
- Renthal Grips
- Avid Elixir R rear brake only
- 140mm Avid G2CS rotor
- Colony plastic pedals
- RockShox Argyle 409 Air forks, rebound, compression and floodgate control. Currently set at 110mm travel, can be lowered internally with spacers. I can do it if you wish.
Frame info: - Frame: Full 520 Reynolds chromoly
- Short 15.1" Chainstays
- Size Long 22.25" top tube
Pictures:
