hifiandmtb
Sphincter beanie
Hey RB - I had mine on max no-Brain & it still annoyed me. It became a bit noisy, and rattled a fair bit too. Yours the same?
Yep.Hey RB - I had mine on max no-Brain & it still annoyed me. It became a bit noisy, and rattled a fair bit too. Yours the same?
I had the same leak issue. All fixed with a left leg service.Dual air SIDs with brain cartridge. They have an air leak somewhere in the positive chamber, leaking down over 24hrs. Hopefully fixable, at the very least a brain cartridge to dissect. Carbon crown and steerer is very sexy.
Looks a bit rough and way too small to be effective, might fit a hipster's shaft though...He said shaft clamp...
This has come a long way! Is the work continually frustrating and laborious? Or is it reasonably interesting and fun?
fingers crossedI had the same leak issue. All fixed with a left leg service.
Same as yours by the looks. Brain cart is doing the right thing in these from a quick play.Those forks are so nice. Aside from Brain.
If you can put up with a 10mm reduction in travel, it is possible to convert solo air CSU's/forks to dual air.
eg. if you take a 120mm solo air SID, add the 120mm dual air spring assembly, with a 10mm all travel spacer installed (110mm mode), then the piston head o-ring seal is now spaced further up the CSU and never gets low enough to cross the solo air dimple. You now have a 110mm dual air SID using a 120mm solo air CSU.
