I'm slowly updating / refreshing bits of my Stumpjumper and am wondering what I can do with the rear shock.
Bike is 2008 Stumpy S-Works with a Specialized AFR with Brain.
To service the Brain shocks they have to be removed and sent to Melbourne and it costs $200-$300. Seems alot of hassle for a 6 year old shock so am thinking that maybe it would be better to replace it entirely with something newer.
Options seem limited though as Specialised do these in a funny 184 x 44 size.
The perfect candidate is a Cane Creek Db Inline as it has the right length however however it has a fat can body with a slightly larger diameter (52mm) than the existing AFR shock which has at its widest point a diameter of 48mm.
I'm thinking that this will fit into the shock mounting but with a very tight clearance to the seat tube, and am not sure how much the shock moves around under compression with the Specialised linkage? Its completely vertically mounted so am thinking / hoping it doesnt move at all?
Attached image shows the current AFR shock in the frame. They have the same body as a Fox RP23 but with diff. internals.
My bike is semi in bits ATM so I have done a fully deflated shock under full compression test.
Any thoughts appreciated.
