Plankosaurus
Spongeplank Dalepantski
I think they might just be a little more sensitive to worn chains, or chains worn to different cassettes maybe. Suffered the shifting on backpedal with one of my cassettes, changed the chain and it's all gone. New chain is SRAM, everything else is Shimano, don't know whether that's got anything to do with it but might be worth mentioning.I know this is an old thread.
I've had two of the 10 speed 42 tooth cassettes.
First one was the all steel one, it would change gears when pedaled backwards. No amount of adjusting would fix that. It wasn't a major issue though. How often do you really do that anyway?
It only lasted about 9 months. 9 Hard, shifting under load, muddy, stick infested, 29er enduro months. I probably should have replaced the chain in that time but didn't realise how badly warn it was in that time.
When I built up the 160mm hardtail I threw a fresh 10 speed 42 tooth cassette and chain on (this time the Aluminium large ring). Its been running perfectly for the last few hundred Kms. Its outlasted my rear deraileur. For the money, I cant complain but if I was doing it again. I'll probably just throw on an 11 speed kit and get a shimano 42T kit.
TLR Value for money, but you'll be replacing them before a shimano cassette.
-Shaun
Now just need to save some pennies and change all my chains.
Sent from my Xperia Z3C using Tapatalk
