yuley95
So I’m behind on some maintenance and I need to buy a few tools before I can get cracking. I need your help to buy the right tools for the jobs below:
Head set cups
I ride a Yeti SB-66 with an integrated tapered headset. I would like to buy just one tool to remove the top headset cup and bottom headset cup but it looks like shops want time to buy two different sizes. Is that really necessary? Also, tell me about diy copper pipe and what size etc you use (if you do)
Headset press - same bike/headset configuration.
Bearing puller
I need to replace suspension pivots (including he switch) and also the bearing in e13 bottom bracket. It’s a threaded bb and the e13 bearings are 30mm. I read on here once about someone keeping the shell and replacing the bearings.
There are a few different size bearings that need pulling and I’m not sure if I need more than one tool.
Bearing press
Need to press all those bearings back in...
Bonus points
I have a Marzocchi 55CR fork and last time I had the air sling open I noticed the small foam ring that sits in a recess behind the air piston seal head was stretched. I need to replace it but there is no reference to it in Marzocchi material. Any ideas on the size or where I can just buy a good set of different size foam rings so I can replace it?
Thanks for any help or suggestions.
Please let me know if I’ve left out important info that’s needed to answer my query.
Thanks!!!
Head set cups
Bearing puller
Bearing press
Bonus points
Thanks!!!
