AngoXC
Uni friend of mine had a galah. She called it Harry till they found out that it was a girl - kept the same name anyways as the bird is a bit of a bastard!Shame it's a female as I called it Gareth. Thanks though!
OK, exposure is off. Treat it the same as a portrait, spot expose for the face and let the background fall as it may. Yes it'll blow out to the top right but you can fix that in Lightroom. If you try and up the exposure on the face it'll start to show noise, so better going the other way. The other thing is the light is behind the bird, try shooting with the light behind you so it highlights the bird. Is that harsh enough?Harsher the better :faint:
I'm a bit curious as to whether the darkness was due to the way I edited it or straight off the camera. I'll see if I can find an original. 100% get what you're saying with the direction of the light, unfortunately the subject wasn't quite willing to swivel and I was on a balcony. Cheers for the hints, very helpful.OK, exposure is off. Treat it the same as a portrait, spot expose for the face and let the background fall as it may. Yes it'll blow out to the top right but you can fix that in Lightroom. If you try and up the exposure on the face it'll start to show noise, so better going the other way. The other thing is the light is behind the bird, try shooting with the light behind you so it highlights the bird. Is that harsh enough?
Nick, here's a tip, if you have a difficult model to work with such as this one, try using a piece of white paper as a reflector and bounce light back up into the models dark areas. Either that or get a model that will happily swivel on it's perch!100% get what you're saying with the direction of the light, unfortunately the subject wasn't quite willing to swivel and I was on a balcony. Cheers for the hints, very helpful.
A bit of dodging and burning in Photoshop should be able to fix your Galah.I'm a bit curious as to whether the darkness was due to the way I edited it or straight off the camera. I'll see if I can find an original. 100% get what you're saying with the direction of the light, unfortunately the subject wasn't quite willing to swivel and I was on a balcony. Cheers for the hints, very helpful.
There's basically no need for a diffuser ever (in my snobbish opinion).Hi all,
I have a gig for our work's anniversary, it's a big deal and the girl that normally shoots these things has cracked under pressure and they have asked me. Happy to do it as I'll be there anyway.
Now, my question is, I have a 580EXII that I'll be using on camera and I was thinking of either using the plastic Stofen diffuser or investing in a cheap one of these.
The location will be a hall/convention centre so the ceilings will be pretty high.
Shooting with 7D + 24-70 f2.8 and a 40D + 70-200 f2.8 for the speakers up on stage.
Cheers
Hux
Awesome! .....Better bump this thread up..
This was actually a focus stack, two images of two exposures each (not HDR), so four photos in total.
Precisely and as I've already told Andrew, AWESOME SHOT.I like it a lot Andrew. When you say "focus" stack, do you mean that there were different focus points with each image as well?
Cheers man, I'm living for it at the moment, hopefully the light shows me some love!Can't wait to see what Andrew brings back from his trip.
Craig told me about the trip Andrew..... so not jealousCheers man, I'm living for it at the moment, hopefully the light shows me some love!
Where was this taken? Is it possible to get a high-res version for personal use as a wallpaper?Better bump this thread up..
Second this. It needs to be blown up HUGE on metallic paper and acrylic face-mounted then hung on a feature wall in a sexy modern house. THAT good dude.Where was this taken? Is it possible to get a high-res version for personal use as a wallpaper?
Thanks!
