Minlak
custom titis
Haakon's alt account is ZafWait. Why? Are you Haakon in disguise?
No.Just ordered a 2.3 Minion SS to go on a 30mm ID rim. Mtbr says I’ll die - is this true?
They come up pretty square (even more exaggerated by the tread pattern), but they ride okay. I ended up missing the volume of the 2.5 Aggressor and swapped back in the end...Just ordered a 2.3 Minion SS to go on a 30mm ID rim. Mtbr says I’ll die - is this true?
You'll be fine. Once upon a time much fatter tyres were put on much skinnier rims.Just ordered a 2.3 Minion SS to go on a 30mm ID rim. Mtbr says I’ll die - is this true?
30. Goldilocks of inner width.Hope fortus 26 or 30 for new wheels to go on 160mm Hardtail?
Cant see me going bigger than 2.5 wide tyre on front.
26 rear is a good option but best suited to run a 2.3" tyre out back only IMO. Fraction too narrow for 2.5's in an ideal world. They'll go on fine, but bottom out more easily as the sidewalls aren't as vertical, and possibly bounce/chatter a touch more or under brakes if the back starts getting a bit skatey.What about 30 front and 26 rear? To get the right combo ie Shimano, 11sp etc
@pink poodle fat bike wheels won't fit frame.Go big or go home @Brow ! 30mm is too narrow.
looks like a rebound adjuster to me. Aren’t lefty air valves in the ‘lower’?Hi again. Turns out I'm not all that up with lefties. Fork seems to run fine on a small road test. Was wondering about the little red cap on top of the fork before I become too heavy handed. Is it some compression or rebound knob or just an air valve cover.
I have had a light try to turn it but no go, should I bring out the pliers to turn it. I'm assuming the lever is lockout, if so, can I remove the ugly lever as I will never use it
Good idea, actually didn't think about that. It came from Kingscliff beach.looks like a rebound adjuster to me. Aren’t lefty air valves in the ‘lower’?
From the look of those bolt heads it’s been in the salt air or a creek for a fair while so you should pull the fork and seatpost etc off and apply some fresh grease.
Fuck fat bikes! But surely you can fit a 33-36mm rim and tyre in there @Brow ?@pink poodle fat bike wheels won't fit frame.
My moto is don't back off unless you are upside down and on fire!
@beeb not likely to go bigger than 2.3 on rear anyway.
With xmas coming, excuse to spend a bit but supply options are quite limited.
Thanks for replies.
Sweat from being on a trainer maybe?looks like a rebound adjuster to me. Aren’t lefty air valves in the ‘lower’?
That would of been before my time then, bugger riding inside. I learnt the hard waySweat from being on a trainer maybe?
