Looking at the Wolftooth B-Rad accessory strap/base, anyone using one or alternative versions ?
Thinking the med sized one will be enough for a multitool, C02 and plug kit wrapped up in a 29" tube.
382244
Cardy George
Bolts on yeah? I'm using a Lizard Skins strap to secure the 4 cell Gloworm battery, it has silicon gripper strips and doesn't move a millimeter
Not this one exactly, but you get the idea.
Yes bolts on.
I have a very similar Granite Rockband strap the same as yours that I have been using but it straps over the top of the tube.
Liking this mounting plate idea as the place that I strap it to on the bike, has 2 bolts specifically for a tool mounting plate.
j0w1s
Shitballs. The ETA for my TRP DHRs getting pushed back. Thanks Commencal.
This is the last component of my Evil Following build, so I need to look at other options.
Choices seem very limited at the moment. I have found either 4 pot XTs or MT5s. Can anyone compare these brakes for me?
Also happy for pointers to other brake sets that are in stock and not shit. Thanks.
Jpez
Down on the left!
So bought a new 2stroke line trimmer from Bunnings. New fuel and oil mix and it doesn’t want to start. I’m pretty clueless with motors so go easy.
Any tips or do I just take it back. I’ve followed the starting procedure to the letter which is pretty fool proof so thinking something is faulty or I’m missing something.
creaky
XMAS Plumper
Does it run for a couple of seconds, or not firing at all?
Do you have a wife or girlfriend? If so, give them a go and it’ll work straight away!
Litenbror
Cura 4 pots at ride sports at the moment. I have the 2 pots and really like them.
Jpez
Down on the left!
Nope. Doesn’t even pretend to start. Like there’s no spark to fire but I don’t know how to test that.
Chriso_29er
Pull the lead off and check if you got spark as you try to start, might be a bit fiddly so might need an assistant.
But first two things I would check, is that being first fuel fill, it has been primed enough. Check the on/off switch hasn't been wired backwards.
If both those easy things don't work, then check spark and remove the plug to see if it is wet.
Tubbsy
Packin' a small bird
Keep on yanking, it'll start eventually. If you've flooded it while priming leaving it a few minutes can help.
Can also try without choke and give it a little throttle as you try to start.
