ここには見るべきものは何もありません
What do you use to get composite pedals looking like new?
Money...to buy new pedals. They have a short life span and are not that expensive. I use them until they are too ugly or fail to feel safe.
Mine are perfectly fine, I just find them hard to get nice and clean.Money...to buy new pedals. They have a short life span and are not that expensive. I use them until they are too ugly or fail to feel safe.
My imagination.What do you use to get composite pedals looking like new?
Depends on whether there is enough distance between the steerer and the topcap to take up the slack in the headset.I was playing around with my bar height and wondered if this was feasible. I suspect not as I'm sure I need a spacer above the stem?![]()
I may have done similar in the past. I would say as a minimum you would want to make sure the upper stem bolt is below the top of the steerer.I was playing around with my bar height and wondered if this was feasible. I suspect not as I'm sure I need a spacer above the stem?![]()
Also, in case you don't realise - you can get 1, 1.5, 2, 2.5mm, etc... stem spacers.
Plenty of people run their stems like that @Jabubu . I don't. I'm all in for the spacer above life. As long as you have tension and contact you should be fine...unless you are turning on the send mode? All the chatter from charging chunder and slamming the bike down will work it loose eventually. If they goes unchecked you'll blow out the headset and possibly ovalise your head tube.
I'm not a sendy person but I do weigh a fair amount (108kg) so I thought I'd err on the side of caution and switch it back before my ride.
Damned sand gets in everywhereBut you can be a sendy person...which my phone changed to Sandy, which you can also be if you want.
That's fine, but you wouldn't want to go much higher, because you begin to lose clamping area. You only need 2-3mm of stem above the steerer to give enough room for the top cap to not bottom out. I'm a fan of the no-spacer-on-top looks, it's neater.I was playing around with my bar height and wondered if this was feasible. I suspect not as I'm sure I need a spacer above the stem?![]()
OK I might put it back and give it a go, it felt good on the ride there!That's fine, but you wouldn't want to go much higher, because you begin to lose clamping area. You only need 2-3mm of stem above the steerer to give enough room for the top cap to not bottom out. I'm a fan of the no-spacer-on-top looks, it's neater.
Oh and I am sort of indulging a finned rotor but most of these are centrelock and my wheels are 6 bolt.
Edit: There seems to be a 180mm finned 6 bolt rotor, RT-MT905 XTR, $95 fml lol.Oh and I am sort of indulging a finned rotor but most of these are centrelock and my wheels are 6 bolt.
Yeah I've got those on the road/gravel and never had issues, even though they are 160/140 setup. Too bad it's centrelock though. I rekon the finns actually do a fair job - the xtrs might be the way to go - justify it with lower temps = longer pad life.finned MT800
