I'm worried with the low resolution she will think it's a crayon pic.Dick pic.
Sent from my SM-G935F using Tapatalk
That’s the risk you take.I'm worried with the low resolution she will think it's a crayon pic.
no don’t want a hub, just the axle with 142x12 end capsHey Daniel. I'm not sure I understand what you are after here, but I think I might have an old Superstar Components rear hub on a 135 wheel hidden in a storage shed on broken wheel. It's not a promise because I haven't looked for a very long time. Is it the hub you want?
‘Caps’ aren’t something your sentences are familiar withno don’t want a hub, just the axle with 142x12 end capd
yes boomer‘Caps’ aren’t something your sentences are familiar with
Case in point.yes boomer
Agreed....unless doing something like hope.pretty sure there shouldnt be any spacer as the HG spline is made for 11speed, and NX cassette was made to fit HG spline
Sure that a spacer didn’t come off with the NX cassette? Possibly the novated free hub is road compatible so came with a spacer?Has there been a change to splined freehub lengths to take 12 speed?
I've taken an 11 speed Shimano cassette of an old XT hub and put it on a newish Novatec boost hub that held a SRAM NX 12 speed cassette, and there's a little bit of slop there. Assume the freehub is slightly wider and I now need a spacer - if so, what size and from where?
So it did, hadn't even noticed (didn't even know of a longer road freehub standard). All good.Sure that a spacer didn’t come off with the NX cassette? Possibly the novated free hub is road compatible so came with a spacer?
Not so much a new standard. Only a thing on these cool companies that make cross compatible products.So it did, hadn't even noticed (didn't even know of a longer road freehub standard). All good.
OK cheers mate. Good luckno don’t want a hub, just the axle with 142x12 end caps
Just cut it out with the angle grinder and use some structural tape over the top.I found this dent.
Quick question, should I worry about it?
The size of a thumb and goes in about 4 mm.
I would already be on a new bike if every bike shop on the world wasnt sold out right now.
pic please, it's not one of those stupid Fox DYAD shocks is it?hey gang, my mate has a 2012ish Scott spark with one of those 3 chamber rear shock set ups! can he swap it out for something like a fox etc
Yeah top tube tube, I'm more worried about it ruining my polished aluminium finish. It's going to take some buffing.Just cut it out with the angle grinder and use some structural tape over the top.
Or, just ride it and don't worry. Top tube?
