I was under impression that the 2018 35mm Revs used same chassis as the Pike, with only difference being internals? Correct me if wrongRev has lighter, less stiff lowers, surely....so I’m saying it’s a fancy rev.
YOU'REWRONGIDIOTFACE!!!I was under impression that the 2018 35mm Revs used same chassis as the Pike, with only difference being internals? Correct me if wrong
2018 I can’t confirm...but the rev are a fair bit lighter I believe, so I just assumed...and assumptions are the mother of all fuckups...that it was like the difference between the Pike and Lyrik. Most likely I’m wrong.I was under impression that the 2018 35mm Revs used same chassis as the Pike, with only difference being internals? Correct me if wrong
GooseSame chassis. As you were.
What’s a couple of inches?Goose
Is this a multiple choice question?What’s a couple of inches?
Enough if it's prefaced by a excellent Chardonnay.Is this a multiple choice question?
A. 5cm
B. Not enough
C. An underdeveloped witchetty grub
What your mum keeps asking me for.What’s a couple of inches?
No, she said for you and a couple of inches was everything.What your mum keeps asking me for.
It was hard to understand through the leather mask. It was covering my ears.No, she said for you and a couple of inches was everything.
It's hard to believe you two are brothers sometimes.It was hard to understand through the leather mask. It was covering my ears.
We are the same person.It's hard to believe you two are brothers sometimes.
Hands have got weakerWhy would an old tyre that has been sitting in shed be impossible to mount again to the same rim ~ 2 years later? Rubber too old and lost elasticity?
Because the tyre knows better...Why would an old tyre that has been sitting in shed be impossible to mount again to the same rim ~ 2 years later? Rubber too old and lost elasticity?
Take the new tyre off the rim first before trying to mount the old one?Why would an old tyre that has been sitting in shed be impossible to mount again to the same rim ~ 2 years later? Rubber too old and lost elasticity?
