Freediver
I can go full Karen
If you painted the ugly bit black you would never see any of it against a black blackground.Paint the ugly bit black. Sorted.
I believe it is as common as toilet paper...where is sydney can i get those scott original shop towel or equivalent? kitchen paper towel same?
Looks like you maybe in luck...will RaceFace Cinch chainrings fit Shimmy direct mount...Damn bike standards, I can't keep up!
The valve was pointing down and only a spot came out? It was probably just the sealant that had coated the inside of the valve stem. Nuthin to worry aboutFirst time tubeless install yesterday. Went to.check pressure this morning and a little sealant spat out the valve. Valve was at the top all night.
Is that normal and should I be worried about it clogging up the pressure gauge?
Not sure about SCAM cranks and the chainring set ups.the shimano rings have a single gap in the notches, silly me for assuming that they wouldn't be compatible (just like everything else)
so how many types are there?..is it just like shown above plus SRAM 3 bolt direct mount, or are there others
I never clamp a dropper, personally. Many do without issues. Nope from me.Just installed a Brand-X dropper. Can I clamp the workstand to the top part of the dropper post, or can that damage it?
Make sure your clamp jaws are clean and smooth. I also wrap a cheap butyl glove around the stanchion.Just installed a Brand-X dropper. Can I clamp the workstand to the top part of the dropper post, or can that damage it?
Or ride alloy bikes and clamp the frames carefree.Never clamp a dropper by the upper bit; the small diameter tube is too susceptible to being bent if there is any torsion on the post from the bike not being exactly balanced. Bend the upper tube and the post is fucked. Plus most workstand clamps won't close down that small to grip. If you have to clamp by the post, use the lower bit because it's bigger diameter and therefore stiffer. If that means raising the post to get enough to grab onto. mark your height with a wrap of tape at the edge of the frame tube so you have an easy reference to drop back to once the work is done.
