Always up for a race!I’ll race you!
My understanding is the width saving in the chain comes from the outer plates thickness and internal dims and rollers are the same.Pretty much, as long as the chainline suits the rear axle, there shouldn't be anything to it.
I think the Eagle chains might not play nice with non-12speed compatible chainrings, but that's different from 9-10-11 compatability.
Your understanding would be wrong; every part of the chain gets narrower once you go more than 9-sp. However there's enough tolerance in chainring tooth thickness to ensure they're not particularly fussy. N/w rings didn't become A Thing until the advent of 11-sp, so by default they're pretty much all going to be designed for 11-sp. chains, so by extension will suit the sligjhtly wider 10, 9 & 8-sp.chains.My understanding is the width saving in the chain comes from the outer plates thickness and internal dims and rollers are the same.
There is no difference in the cranks it’s is the chainring itself that takes care of any change.Thanks @Duckmeister. Am I correct then in assuming that there isn't any spacing differences in the crank design to deliver a slightly different chain alignment that will only function with 11speed set ups?
Excellent. This is what I thought, but didn't want to burn up cash to discover I'd been "boosted" by a few mm of betterererererness.There is no difference in the cranks it’s is the chainring itself that takes care of any change.
I would strongly suggest waiting for confirmation. I just know that last 2 sets of cranks I bought they swapped out the chainring from the “boost” branded box to a non boost chainring.Excellent. This is what I thought, but didn't want to burn up cash to discover I'd been "boosted" by a few mm of betterererererness.
Thanks all.
Wait? I've already purchased 3 new ones and had your name and likeness engraved on each of them. You can't do this to me now!!!I would strongly suggest waiting for confirmation. I just know that last 2 sets of cranks I bought they swapped out the chainring from the “boost” branded box to a non boost chainring.
The direct mount chainrings I have here are either 6mm non boost or 3mm boost on the actual chainring
I just can handle the responsibility or being right.Wait? I've already purchased 3 new ones and had your name and likeness engraved on each of them. You can't do this to me now!!!
So glad you like that. I was worried at first that you'd find it wierd.I just can handle the responsibility or being right.
Anyway.......
It’s ok it will go along nicely with your tattoo of me on your penis.
Well we did agree to get matching tattoos it is what it is.So glad you like that. I was worried at first that you'd find it wierd.
I still don't understand that. Why did you want a tattoo of yourself on your Willy?Well we did agree to get matching tattoos it is what it is.
What can I say I like to see myself finally going places.I still don't understand that. Why did you want a tattoo of yourself on your Willy?
And you are well travelled.What can I say I like to see myself finally going places.
