The Tyre Pressure Thread
What Pressure do you run in your Tyres, if different F - R please list the higher
  • < 15psi
    Votes: 2 2.6%
  • 15-18psi
    Votes: 1 1.3%
  • 19-24psi
    Votes: 36 47.4%
  • 25-28psi
    Votes: 34 44.7%
  • 29-32psi
    Votes: 10 13.2%
  • 33-36psi
    Votes: 7 9.2%
  • 36-39psi
    Votes: 1 1.3%
  • > 40psi
    Votes: 3 3.9%
  • Tubes
    Votes: 7 9.2%
  • Tubeless
    Votes: 21 27.6%
  • Total voters
    76
Mattyp
Going off a recent conversation, interested to see what people are running, feel free to elaborate on Tyre / Rider Weight / Cushcore / Type of Riding
Mattyp
On my Enduro bike, F: Assegai exo 32psi / R: DHF exo 34psi, 82kg , rode this setup most recently in Bright, but is pretty much my goto starting point depending on terrain.
Odious Geriatric
Depends...
On soft sand 4/6 pissies on the fat bike, 26x4.7
Usual trail stuff on the Bronson is 19/24ish, 2.4 / 2.25 650B
Hardtrail stuff where the fork is locked out on the hardtail anything up to 40... 2.1 29er
90 kg.
Hard to answer without knowing the trails, bike and how hard the police are chasing.
Calvin27
25f/28r tubeless for the am rig. I've run lower front but these days I fill her up to 25/28 and check it once a month :p.
30f/40r tubed for the xc rig. (mainly because that bike is infrequent use)
81kg
kten
Assegai 2.5 EXO 22-24psi
Dissector 2.4 EXO 25-27psi with cushcore
30mm internal rims on a hardtail
88kg
creaky
The obviative
82kg
23/24 F on 2.35 tyres, 30mm rims
25/26 R on 2.3 tyres, 30mm rims, a psi less on the dually
No pool noodles
Isaakk
22-24F, 2.35 tyre (currently Aggressor Exo), 28mm rim
23-25R, 2.25-2.35 tyre (currently Forekaster Exo), 25mm rim
84kg, mostly just trail type stuff.
Ultra Lord
95kg
30psi front- 2.5 assegai exo
32-34psi rear- 2.3 aggressor DD
Just tubeless. Rear gets dinged every now and again when I mess up and do something stupid.
stirk
Mind blown with possible options, can't possibly offer useful response other than my own opinion,........ I should be a politician.
Cardy George
Wax on, wax orf.
80kg, on a hardtail, flatland XC.
Depends on the ride. General purpose commuting it's 20f/35r to support the weight of my bag. Race day it's down to 15f/28r to cope with loose sand over hard pack, generally mid-corner.
Tubeless Forever.
BT180
Max Pfaff
Geezus, does everyone on RB weigh 80-89kg?!?!
Yep!
82kg
F: 18psi
R: 22psi with Cushcore
Rims are 30mm internal
Usually on Maxxis Assegai front with DH casing to aid in sidewall support and rear Exo+ DHR2 or Assegai, but now testing Contis. Seem to be holding up so far.
Ride very rocky terrain and this combo seems to be the sweet spot. Will increase pressures a few PSI for bike park riding
What other people have in their tyres is irrelevant to just about anything unless the person is your twin and has an identical bike and riding style. I run different pressures all the time because on different bikes, rims, tyre protection, trails and with fluctuating weight.
alrsv1
Pivot Mach 5.5 with 140 travel rear, 160 front
2.6 width tyres on 30mm rims and 73Kg rider,
Minion front, Forekaster rear.
Was running around 18/20 but after doing a cornering clinic recently started trying around 24/26 and working on technique to find grip rather
that relying on the tyre as much, enjoying the faster rolling as a result.
caad9
I have a Kona Satori DL 140 front and 130 rear.
80kg
Run 22-23 Front (2.3 Minion DHF Exo) and 25-26 rear (2.3 Aggressor Exo)
Both tyres use Nube inserts (think pool noodles)
