Thoughts on Stan's 3.30 hubs
rowdyflat
chez le médecin
OK still going anyone have an opinion about Novatec
Novatec MTB Rear Disc Brake Hub 24/28/32 Hole 135x9mm w/142x12mm Adaptor D792SB
SummitFever
Novatec use a 15mm axle. They make a steel axle and an alu axle. Alu axle is weaker and typically results in freehub failure at the pawls or the axle itself breaking.
If this hub weighs 274g it probably has the alu axle. Steel axle version is bullet proof. You can retrofit the steel axle later.
SummitFever
Then its probably steel. They also do a steel freehub which is stronger, so could possibly be steel freehub and alu axle. Maybe you can ask seller.
