Twisted&Broken
No issues with thread lining up. There is no female thread on the roof rack, just a hole for the bolt to go through.
The Outback doesn't have bolt-on racks though - it uses longitudinal roof rails that the Thule system clamps onto?Carpetrunner. I used to be a sales rep selling threebond which is another brand of thread lock so know and own all types of locking compound. Again its not finding and fixing the problem in my opinion. I believe the bolts are mild steel as are the "nuts" on the car. No stainless or zinc coat. The bolts don't rattle in the nut and three sets of bolts and no sign of damage to the thread when removed.
Every bike a a roof rack I've seen sways a bit. My brother in law has a subaru outback and has no issue with the same racks. I don't think its excessive movement of the bike.
Even more so when you consider the car has a sunroof.I think roof flex will be the culprit,
Just saying that if there are flex issues with roof area causing issues with your racks then this would be compounded by the fact you have a sun roof.John u. So you think my car is flexing more than all other subaru liberty wagons with genuine or thule roof racks? Thule say they have never heard of this before.
Guess you have done that checking. Ignore my post.I already have the fitting instructions and have double and triple checked the fitting along with the Victoria rep for thule and the retail shop I bought them from.
Really? 4Nm really isn't that much torque at all, if the bolts were way under I'm suprised they stayed tight at all.Well. i just picked up the tension wrench and checked the bolts. They were way under 4Nm and when I tried tighten them to 4Nm as specified in the fitting instruction they deformed the rubber quite a bit and then cracked the trim on the roof of the car.
