HamboCairns
Thanks for all the bananas
Hi all!
I'm looking at getting tyre inserts as I want to run lower pressures but avoid bumping against the rim all the time.
So far I've seen -
Cushcore Pro (Expensive and heavy)
Nukeproof ADR (Inexpensive and light, but they stretch)
Huck Norris (No idea)
And now a new one from Tannus called 'Armour Tubeless' which apparently tests well, is light, inexpensive, doesn't stretch, doesn't absorb sealant and doesn't make tyres hard to put on or take off.
It's not available in Australia yet but I've emailed the distro.
Does anyone else run a tyre insert? Did it change the way you ride, the character of the bike, make you a hero?
So far I've seen -
Tannus Armour Tubeless
Tannus airless bicycle tires are puncture proof bike tires that don't go flat. Bike tires that are solid and made out of a lightweight foam that will last long
tannusamerica.com
