Have you already looked into this?Coil on that! But you can't because not enough space around the chips or around the linkage
Has it already got a float x?
I did when I owned the instinct.Have you already looked into this?
yeah, looked at it this morning and realised it wont fit, should have done that before i posted this thread dumb ass i am.
The linkage interferes with the coil.
Not necessarily a bad thing, there are some stunning air can shocks on the market now.yeah, looked at it this morning and realised it wont fit, should have done that before i posted this thread dumb ass i am.
looks like air shock it is.
I think it's already got a float x on it so may fit an x2 in there...Not necessarily a bad thing, there are some stunning air can shocks on the market now.
Does it have the clearance for a Float X2 or a Vivid Air?
Failing that, a custom machining of that link which gives more clearance on the link would be nice.
The fox float X2 does fit in a rocky Mountain altitude as pictured above; however, it will only allow you to run the ride 9 in the slackest and heavier weight spectrum ( front, middle lower, and bottom) the other 6 adjustments are out of reach as the air can contacts the linkage to frame pivot. I'm running one right now and it is an amazing setup but I think I'm going to sell it and get a DVO topaz Instead to maintain the adjustability. If you only want the slackest position on this bike is would strongly suggest the x2 though. If anyone is interested in buying a lightly used one in 200x57, let me know.So it fits! Can you run the ride 9 in the slackest position? The can looks like really close to the frame
