EP, you are still left with any team with a reasonable budget being able to win by running 26ers at the same amount of effort and $'s as they make for the 29ers. I reckon Scott would rather win on a 26er than have trek or spesh win on 29 - unless there is a conspiracy? Marketing depts want podium shots for their next print adds, 2nd place doesnt cut it, it needs to be first, and the bike wheel doesnt need to be in shot, you just need your rider on top.
Corporate marketing strategy doesn't work that way. In bikes, everyone has 2 x26's and sales were slowing - ask your local LBS. Scott had a 1st and 2nd in 2010 on 26FS - unprecdented - yet changed to 29 to get momentum in the sales room.
In the Pros/Cons of 29s thread I presented/quoted and linked studies on power regarding 26/29 and tyre volume, professional views and observations of two WC XCO coaches, two wrenches who are now working or have worked on WC XCO teams ...
Thru all this you posted your opinion... not one fact, not one study or professionals judgment to the contrary.
You seem to be still struggling with the fact that a shallower incidence angle/volume of a 29 will not overcome the additional weight of an off the shelf 29 wheel/tyre.
And struggling with the fact that WC XCO don’t use off the shelf 29 wheel/tyres
I showed studies with multiple riders, multiple courses, over multiple days all you could do was argue over what ‘published’ means... or complaining that the figure of 7% must be too high because you think it is...
(For those who are bright enough not to go near the 29forum and insinuate their bikes and 650s are mostly a marketing exercise when it comes to speed but are interested in the studies etc...
http://www.rotorburn.com/forums/showthread.php?236632-Pro-s-Con-s-of-the-29er/page2 and starting again at
http://www.rotorburn.com/forums/showthread.php?236632-Pro-s-Con-s-of-the-29er/page8 )
If you think the figure of 7% is a lot for an added 14% of wheels and 11% tyres and tubes/sealant ...
Why has not Speccy/Giant/Trek/Scott/whoever made available some of the thousands of hours of power figures they have to counter those studies?
Rather than Specialised getting an employee to ride a hill a couple of times with a HR monitor on his race bikes and sticking it on Youtube – if normal off the shelf 29s are indeed inherently quicker or even the same - why wouldn’t they just grab a power meter from their semi trailer of equipment and ride with that?
Why did no-one in WC XCO start racing 29ers till the factory teams got on board?
Why amongst the 200 or so starters in mens and womens WC XCO – save for a few - are generally only some big factory teams racing 29s or 650s?
What percentage disadvantage do you think it would be to add 50gms a tyre for sidewall protection?
If you gave a passing thought to those questions how about being able to find some positive data on ...
Any test results of at which point tyre volume - and therefore mass - becomes a disadvantage - that is, the crossover point?
What about incidence angle - happen to come across anything that might give an indication of the actual effect of this in percentage gain? Incidence angle being the only thing effectively different between 26/29/650 once tyre volume and wheelset weight is taken out of the equation – two things easily manipulated.
Any ideas on the 'retarding lever' percentage gain/loss of the different shaped contact patch? Tyre contact patch is going to be different between 26/650/29 for the same volume and therefore the same potential psi
These questions are related... Over the last 4 mths I have been sent power data for different analysis (nothing to do with tyres etc rather robustness of an aspect of the data collected)... everything from ht v softail, normal sidewall v heavy sidewall, tubs v skinnys, high pressure skinny v lower pressure baggies... different courses for some, particular courses for others... 26 on tubs v 29s on skinnys v 26 on baggies on one particular course, 29 on skinnys v 26 dually v 26 softail... grippier tyres v wider low knob tyres on a variety of courses... and a bunch more ... all on race wheels with very fast, obscenely skilled guys/girls on WC courses or equivalent test courses ... smallish data sets and of no relevance outside WC XCO ... obviously (although probably not to you) nothing comparing 26 or 29 wheels that you and I can buy.
The point being that if you have anything at all that passes for data regarding off the shelf 29s, any data at all, that even sniffs of fit for purpose, has a mention of methodology and a passing interest in control then the good folks here who are into racing would love to hear about it.
Remembering this post is about speed on short course XC. Marathons are different where comfort becomes important.
Regarding WC XCO – the range of tyres and wheel weights is quite amazing. There are girls racing Furious Freds and Ikons with sidewalls on the same cct, it really is all about race tactics – where a rider/coach think there may be advantage on a particular section and how the rider thinks the race may unfold.
