Not when he cuts it too short and on an angle.That looks solved.
I haven't done that for years! I use a cutting guide now.Not when he cuts it too short and on an angle.
pffttt.. cutting guide? Torque wrench? It's all in the hands M80s... I use a cutting guide now.
I'm only good with a large blunt thing in my hand...so big a few mm here or there wouldn't matter anyway...pffttt.. cutting guide? Torque wrench? It's all in the hands M80s.
+1. Rangersac - It's your life mate, but NO. Frikken NO.I have nothing to back it up but the top bolt should IMO be below top of steerer by 2.5-5mm. You are out by what, 3mm?
There's prob people riding around doing just that and oblivious to it, but I'd prefer not to be a stat: too short for me.
Lower topcap or weightweenies favourite no topcap?Thanks gents, yeah it's a piss off, I reckon I need another 3-4mm only and then I'd be fine. Using a replacement stem is a bit tricky as it's a 120mm job, and most of the low stack ones are short. One option is the current top cap on headset is pretty chunky at 8mm. Might head for the LBS and see if they have an orphan flat top cap, as that would get me what I need. Alternatively what's the lowest stack external top cup 1 1/8th headset anyone know of? Currently stack height around 19mm
A different top cap will definitely fix the issue.Thanks gents, yeah it's a piss off, I reckon I need another 3-4mm only and then I'd be fine. Using a replacement stem is a bit tricky as it's a 120mm job, and most of the low stack ones are short. One option is the current top cap on headset is pretty chunky at 8mm. Might head for the LBS and see if they have an orphan flat top cap, as that would get me what I need. Alternatively what's the lowest stack external top cup 1 1/8th headset anyone know of? Currently stack height around 19mm
Is that a metric or a imperial bee's dick?Who says Campagnolo and mountain bikes don't work? One Centaur headset top cap later and she's apples!
Everyone knows that dicks are always measured in imperial unitsIs that a metric or a imperial bee's dick?
