+1. Toooodalllllyboeshield t9 hands down best thing going around
I went from the squirt to Boeshield. Both great Boeshield better+1 for Squirt. Last for a long time and doesn't pick up junk.
I will be trying Boeshield after I finish my big bottle of Squirt.
It's not very sticky, and pretty expensive. That's why most arborists use motor oil instead. Chainsaws have it being pumped on continuously, so it's designed to lube, but not stick like Bike chain lubes.Stihl Bar and Chain oil. ( For Chainsaws) dribble on, wipe excess off and away you go. Buy a litre it'll last you ages.
It's not ment to be too sticky, thats why it works, not much grit gets stuck to it. Not cheap??? Tell me where I can get 1L of chain lube for about $10 your green oil is about that for 100ml.It's not very sticky, and pretty expensive. That's why most arborists use motor oil instead. Chainsaws have it being pumped on continuously, so it's designed to lube, but not stick like Bike chain lubes.
I'm using Green Oil, seems do be doing the job.
It is meant to stick but. Otherwise any oil would do. Chain saw oil isn't designed to stick like chain lube. But still, if only $10 a liter, used every ride, it'd possibly work depending.........It's not ment to be too sticky, thats why it works, not much grit gets stuck to it. Not cheap??? Tell me where I can get 1L of chain lube for about $10 your green oil is about that for 100ml.
Wouldn't go spreading that around :target:I bulk buy any lube I use and get it cheap.
I wouldn't go spreading that around :croc:I'm using bar oil cause I get it for free
