PJO
in me vL comy
Are they vibrocore rims?Cheers. Only got one bag of washers with the rims so will need to order others will check their thickness and allow for that.
I built up a vibrocore 350 and a vibrocore 359. The 350 was an earlier model and the 359 a later model.
At the time I was confused because I only had one bag of washers but instructions for both rims talked about washers. It turned out that the later model rim had the washers already in place and held in by the vibrocore foam.
Can't remember where I found the info but there was something written up about how spank had changed the way they do the washers with the vibrocore rims.
You sure you don't have washers already in there? If one rim is vibrocore chances are you might?
