So George............... tell me more about your 2+2 racks then. When are they available?
I will be in the market early next year.
Will need a 2 bike carrier for 95% of the time on either the Commodore Wagon or Hilux Dual Cab with Canopy. The other 5% and need for 4 bikes will be on the back of the Jayco Hawk Offroad Camper that has a hitch receiver already.
Do you have a factory / showroom that I can come and have a look at your carriers?
Can I also suggest selling wheel hoops for 16" and 20" wheels.
We've been shipping the 4x4x2/4x4x4 family with the ability to convert between the two for several months now. Just haven't announced it yet but will when we have production capacity up and can satisfy demand. I've been using that combination for over a year and love it.
No problem with both vehicles. Know them well and it's the same compact main beam carrier for both except for the pivot base. One for each vehicle - compact high profile on the Commodore and extended high profile on the Hilux in order to deliver improved departure clearance over the low(ish) tow bar.
We can point you to a bike shop if you prefer.
No problem either with smaller bicycles - been supporting them for years. The standard wheel support cradles support and stabilize wheel formats between 24" and 31" with tyre sizes from ultra-thin time trial tyres on solid carbon rims through to 2.7" wide downhill MTB race tyres. The *only* contact with the wheel cradle is at the tread and not sidewall. When the going gets rough, regardless of the bicycle wheel and tyre type, we make sure that each wheel is stabilized at two contact points and that there is never any chance of marking a rim - especially a carbon fibre rim. If a tyre goes flat during the journey, the wheel remains stabilized and protected - and the bicycle secure.
When the wheel format is smaller than 24" we usually just swap these wheel support cradles with a smaller size that we manufacture specifically for 16"-26" bicycle wheels. There is an overlap in supported wheel sizes between the two versions of wheel support cradles.
If you ever cross to the dark side and take up Road Bicycles, the same components as above support, stabilize and protect the most delicate of light weight carbon fibre road bicycles. We even have several adventure racers who cross the country with 7kg time trial bicycles on carbon rims and you don't get more fragile than that. Because the bicycles are so well stabilized, you never have to deal with fretted wheel and head stem bearings on a hard corrugated trip.
With the Hawk camper trailer, the same hardware as the Hilux should be fine. We can give you some pointers on the rear mount. That camper however does like to be well balanced - particularly at high speeds and in the event of an emergency turning manoeuvre. With the 2+2 configuration of the proposed carrier for you, you have the ability to split into two carriers - which is again unique in the industry. That means that you are able to configure 2 on the front and 2 on the rear - or 1 and 3, or 3 and 1, etc. Fine tube the trailer balance and ball weight for the perfect trailer dynamics. That's gold for relaxed travel.
If you do split into two carriers then the forward tilt pivot base will allow you to tilt up and forward to access the storage compartment on the front of the Hawk camper and to deploy the bed. A bit like this Mission off-road camper trailer:
Hope that helps.
Apologies up front Boomer. It's just our style to be thorough with communications so that there are never any surprises.
