they may well be similar/same, but personally for the sake of $20 I'm happy to buy something made specifically for the operating temps/performance of a mtb fork that requires replacement every 50 hours as opposed to an oil made for vehicle operation requiring replacement every 10000 kilometres.I thought most people just use motor oil?
Engine oil works a lot harder than fork lower leg oil, you wouldn't see anywhere near the loads or the temperatures. The temperatures at what fork oil is rated at is different from brand to brand anyway.they may well be similar/same, but personally for the sake of $20 I'm happy to buy something made specifically for the operating temps/performance of a mtb fork that requires replacement every 50 hours as opposed to an oil made for vehicle operation requiring replacement every 10000 kilometres.
Because what a crock selling in tiny bottles each time.Also why do you have to buy 125/250/500/1000ml of a product you only need to use 10/15/20ml off ffs. I've got 975 ml of left over 15wt oil already.
Maybe the whole fork was designed with low viscosity to start with. Unlike a car engine, the lower number probably has more importance than the higher number as most of the time fork oil is not going to be near 100 degrees C.but why do they use specifically an oil that has a 0 winter weight? Surely the fork doesn't need a lower viscosity on cold start up? Shirley they could just use a std 5/10/15 weight oil in the lowers like they have before, or is this another stupid standard?
I disagree. it would make more sense to at least have a single use product (like in a syringe so you don't have to buy that too) for infrequent users, therefore you don't have the actual oil itself going to waste. At a minimum you're looking at 6x services so 2-3 years worth for me.Because what a crock selling in tiny bottles each time.
Wasteful packaging for something that needs doing pretty regularly.
Use the 2 stroke oil syringes without the rubber seal, the thumb-pull ring ends up snapping off but you can bolt a flat piece of ally or steel to the end of the plunger and they last for years. Rockshox also sell 120ml bottles.I disagree. it would make more sense to at least have a single use product (like in a syringe so you don't have to buy that too) for infrequent users, therefore you don't have the actual oil itself going to waste. At a minimum you're looking at 6x services so 2-3 years worth for me.
it more seems they are selling it in shop amounts to discourage home mechanics.
So...waste a syringe each time too. Worse than @HaakonI disagree. it would make more sense to at least have a single use product (like in a syringe so you don't have to buy that too) for infrequent users, therefore you don't have the actual oil itself going to waste. At a minimum you're looking at 6x services so 2-3 years worth for me.
Killing the environment as usual.What did I miss?
Oh right. Stupid environment, it knows what it did....Killing the environment as usual.
let humans breedStupid environment, it knows what it did....
