Bugger. I accidentally bought a set the other day.Yep, Positive.
Yes, hens teeth. Any decent straight steerer 29" is.Can't, or won't?
http://www.ebay.com.au/itm/372016288952
Going to be easier to find a straight steerer fork with qr than it is with 15mm.
Sent from my D5803 using Tapatalk
I had some xfusion slides with straight steerer and 15mm but can't remember ever seeing something from rs or fox with that combo. Could possibly throw newer lowers on an older fork but that means buying two forks and praying to the gods of backwards compatibility, maybe sacrifice a goat for good measure.Yes, hens teeth. Any decent straight steerer 29" is.
Bought these for daughter. Wheelsize wasn't listed..I stupidly assumed 26 :doh:
My mates XX with munted stanchions and 15mm, and my qr, SS are compatible afaik. Would just swap the csu and internals. Not a big job, and the 2 sets come in at about $250...but not something I am needing.I had some xfusion slides with straight steerer and 15mm but can't remember ever seeing something from rs or fox with that combo. Could possibly throw newer lowers on an older fork but that means buying two forks and praying to the gods of backwards compatibility, maybe sacrifice a goat for good measure.
I've run an adapter like the one above on multiple bikes and multiple wheelsets with no issues, good solution for annoying straight steerer tubes.
Oh, they exist...you may just struggle finding someone to part with theirs. GLId rather not have to try and put two pairs of forks into one. But yes you are right its definitely a want to no go quick release. But I currently have the fox F29 for so they definitely exist with the specs I'm looking for.
