WTB: 475lb or 500lb coil spring
kurtis1984
Item: 475 or 500lb coil spring, 2.75 inch stroke, 145mm or more free length. To fit a Marzocchi coil, so it has to be a 36.5mm ID.
Location: Perth, but will pay for post for the right price
Item Condition: 2nd hand is fine
Reason for buying: I'm wanting to try above my current rate of 450lb
Price and price conditions: $20 and up I guess
Extra Info: It doesn't have to be fancy, I just want to be able to trial a firmer spring to see if that's what I need.
Pictures:
The H
Hi, have this at home. Will double check ID if interested.
Light weight Manitou spring from a Fox rear shock.
500lbs X 2.75" stroke, 150mm overall length 36mm ID
Weight 318g
Save some grams from steel, was ~175g for me
351745
kurtis1984
That looks pretty good actually. I'll have to check if a 36mm ID works for me.
Edited: If the ID is indeed 36mm it will fit. Please let me know the price.
Cheers,
Kurt
The H
Cheers,
Kurt
Hi,
I have it on FB sale group for $50 so add $10 for postage. I will check what ID is exactly with the Vernier's.
kurtis1984
Cool. And it weighs only 318g? That's a fair bit lighter than my Nuke Proof.
Also, could you please get the OD as well? Just want to make sure it will fit with the reservoir.
Thanks.
The H
Hi sorry been away, 55mm OD. Yep is light weight in comparison to others out there it is Titanium. ID is just over 36 around this to 36.4.
