Washers are preferred, but not the end of the world.Take one bolt from your other bike into a bolt shop and grab them from there. Just make sure they have washers.
Specialty bolt shop will have you sorted. A bike shop should also have you sorted easily. The bolt shop will probably leave you with change from $1.00.ok so they are standard item, no weird thread etc? easy solution thanks.
yeah true, thanks... I have to get a bolt for the pivotal seat post also, looks like M8 size. Nearly have all the bits to start building!Specialty bolt shop will have you sorted. A bike shop should also have you sorted easily. The bolt shop will probably leave you with change from $1.00.
More than once I've parked my bike in the nearby bolt specialist car park and pulled bolts off for the guy behind the counter. It is good to run quality bolts.yeah true, thanks... I have to get a bolt for the pivotal seat post also, looks like M8 size. Nearly have all the bits to start building!
