Xt 8100 or 8120 with 10-45 cassette?
Scotty675
Cable thief
I set limit and b screw with chain on with the derailleur I just fitted. This is a second hand 8100 I picked up so this was first time fitting. I always set b with chain on as I see it as this is were the derailleur will definitely sit while riding (under tension). Limit screws I normally set without chain or cable first then do a final check once everything is fitted up.
bear the bear
Is a real bear
I can't find the thread from last time either.
This is not the diagram I posted last time, but it explains the compatibility for parts:
367118
DMan
Ok, this is the closest I can get with the b limit screw all the way in.
bear the bear
Is a real bear
@DMan @Scotty675 assuming that you both are using a version of RD-Mx100-SGS, the clearance that can be achieved via the b-screw is dependent on chainstay length and derailleur hanger geometry. This may allow suitable performance, but Shimano does not guarantee/ recommend it
DMan
That would explain why I can't get closer. Just the best I can get then?
Scotty675
Cable thief
@DMan this is reference to mine perfectly adjusted. This gives perfect single and multi shifts up and down.
Other 12 speed set up runs a 52 sprocket and this position is also the sweet spot.
These pics are m8100 derailleur and 10-45xt cassette.
367135
367136
Can you post a pic of your derailleur in the smallest cog. So I can see derailleur position
DMan
View attachment 367135View attachment 367136
How is this?
Scotty675
Cable thief
Sorry one from the side of the bike. To show the angle the cage sits at. From a distance would be good to show all of chain
DMan
Do you have any spare links for chain and a quicklink?
Chain looks a little short
Funny you say that as I broke the chain and had to take 2 links out! I wondered if it was a bit short now. I haven't so I might just throw a new chain on it.
Scotty675
Cable thief
I can throw a couple of links and a quick link in the post if you like. I recon you will be back to smooth shifts in no time.
