XT M8000 Brake - no power
FatMuz
I bought a set of new XT M8000 brakes off a Rotorburner a week or 2 ago. The rear brake feels quite soft and lacks any stopping power.
I've bled them twice now and changed the pads from resin ones to new sintered ones... and it still lacks enough power to pull the bike up, even on damp grass I can't get the rear wheel to lock up.
Help needed...Anyone got some advice or tips?
Cheers
Muz
Ky1e
Possible contamination. Some emery paper on the rotors and pads should clear it up if contaminated
creaky
XMAS Plumper
When you say it feels quite soft, do you mean the lever is spongy ? If so, it's got to be air or a dodgy seal.
Hell no. Wash rotors in hot soapy water then rinse. Cook the pads. If spongy, will also need a bleed.
Ky1e
Sand the pads back to metal and you might remove the soaked in contamination....
All I know is moorey I have not had one single issue with brake fade in over 2 years, resin pads, metal pads, m785, m8000, slx. But that's cool. Whatever.
Muz
When you say bleed, did you do a complete flush, I had a similar problem with my XT's, A simple bleed didn't work but doing a complete fluid change worked a treat, The old fluid was very gungy and discoloured
I'm sure you haven't...as I don't reckon you've had a proper contamination like this sounds. Shimano' good like that... :woot:
It could be a combination of things, I would try and re-bed the pads in first. Roughen the rotors and pads with course grit sandpaper and try not to overheat the brakes on the run in period. With sinted brake pads, it normally takes me about seven brake applications in the yard at highish speeds and I can start to lock the brakes up.
skinnybeans
As people have kind of alluded to you are describing 2 possibly seperate problems:
1. Brake leaver spongy
2. No stopping power
If your lever is spongy there's no point fucking around with the pads and rotors, because the problem is going to be with air in the lines or seals.
If you get the lever feel sorted out so its solid and you still have no braking power the proceed to pad/rotor treatment.
stirk
Thinking completely left field, are you running a mount for a 203mm rotor but have a 180mm rotor installed on bike?
Yeah I hear everyone laugh but stranger things get you into the fuckwit thread!
The Duckmeister
Has a juicy midrange
This is on the money.
If the lever is soft, bleed the brake properly to get the air out of the line.
If the lever feel is solid but there's little or no friction, which is common with new metal pads, give the pads a good scuff with some sandpaper. Leave the brake dust on the pad surface, 'cos you'll need to embed this into the rotor surface.
DO NOT clean the rotors unless you can actually see oil covering the surface!!!! Continual cleaning strips the layer of embedded pad material, which is essential for proper brake performance, from the rotor surface, preventing the brake from generating full power.
schred
Mr Duckmeister, following from this may I please ask you your view of Muc-off cleaning product applied liberally to all things bike, including rotors/calipers?
The Duckmeister
It's fine. While great at cleaning general dirt, it doesn't have the aggressiveness to strip ground-in brake material. :smile:
Dozer
Heavy machinery.
It needs to be bled properly as others have said, that may mean doing it a few times and using some of the methods and tricks not outlined in Shimano manuals etc.
As far as Shimano goes, if you ride anything that points down and you are of a manly shape over 90kg then anything Shimano under quad piston is junk. In fact, of the six sets of Shimano brakes I've used over the years I can safely say that I would not put any of them on a bike that is ridden on a gravity fed trail or going over 30km as they don't stop good enough and "the pedal goes to the floor" too easily.
JTmofo
XC Enthusiast
Hope E4/V4/M4........ Close thread
will2
Gee, that's bold.
