Cardy George
The thing is over forked as it is.......My XC bike runs a 150mm pike. Get your priorities right.
(actual elevation profile)
Wait. You ride yours? Fuck that.
Too old for that shite! My wrists don't like me now!Time to go with a rigid fork Cardy, you XC blokes froth efficiency and weight saving don't you?
You should alternate hands. Also, sit on the unused one to make it go numb. Hello ‘welcome stranger’My wrists don't like me now!
You have an XC bike? Who 'da thunk it..........My XC bike runs a 150mm pike. Get your priorities right.
Yes. It’s only 140mm rear, and not much over 13kg. That qualifies. Right?You have an XC bike? Who 'da thunk it..........
Errr, of course......... Your trail bike must have 160mm and 16kg too.Yes. It’s only 140mm rear, and not much over 13kg. That qualifies. Right?
Before or after 99?You should alternate hands.
No, thats Felix’s. Mine are lighterErrr, of course......... Your trail bike must have 160mm and 16kg too.
Upsizing is the new black.
29.But they are pike. Wait, what size wheel is he running? 26 would be an improvement over anything, but the cost....
He definitely needs marzocchi.29.
and Pike Dj don't have the same compression set up as normal pikes.
No arguments here.He definitely needs marzocchi.
So you won’t run a dropper for weight but will run an italian boat anchor that is eithee barely holding sag or bottomed out with no in between?No arguments here.
But preferably real Marzocchi, not rebranded Fox
Tradition. I was a roadie for a period tooSo you won’t run a dropper for weight but will run an italian boat anchor that is eithee barely holding sag or bottomed out with no in between?
You need to wash your mouth out with soap. Nasty bad tasting soap. Probably the soap with grit in it that is used for cleaning grease off people's hands.So you won’t run a dropper for weight but will run an italian boat anchor that is eithee barely holding sag or bottomed out with no in between?
Like that oneWhen the maggie doesn't even bother for a second swoop coz it know your no threat
*edit ...
