Here is my super pedantic method;
1. Spin wheel then slam on brake lever and hold firmly then tighten bolts partially.
2. Check evenness of pads by shining a flood light through caliper from other side so the pad/rotor gap is visible. if during the day then sunlight works even better.
3. Squeeze lever progressively and ensure pads touch rotor at the same time, from both sides and at each end of each pad. The rotor must not be deflected to one side by the brakes otherwise it means your caliper is misaligned or you have a lazy piston.
4. Check step 3 at various points of the rotor circumference, and true the rotor if excess runout.
5. If need to adjust caliper alignment then loosen one bolt slightly and realign caliper by hand using light as a guide. If there is a lazy piston then remove pads and extend pistons then clean all around them with alcohol and a toothbrush then start at step 1 again.
6. once happy with alignment hold brake lever on hard then tighten caliper bolts whilst alternating between each one, but no more than maybe a 1/8 turn at a time to prevent inadvertent movement. don't need to crank them down too hard or you can strip the threads; spec usually about 5Nm.
This method takes longer but I have never had issues with brake noise (except sometimes when wet), or uneven pad wear. Must also ensure rotor bolts are tightened progressively in a star pattern to an even torque.
if you can, get rid of the avid CPS mounting hardware it makes the job that much harder for no perceived benefit.
