I suppose it's time for an update.
Last one was regarding new brakes which are still going strong, no issues at all and really love the increased power and modulation over the old single pot avids.
Have done a few high speed break burner descents and they are just flawless with such a soft touch they hardly ever lock up even when it's super loose.
Recent changes have been
New PG1070 cassette
Modded cassette with oneupcomponents 42t and 16t
New chain - broken 3 rides in.
Changed 32t xx1 ring and spider for 34t direct mount NW from wolftooth components.
A little bit of playing around with suspension setup too. Tweaking LSC on fork and increase in pressure from 85-90psi.
Slight increase in pressure on shock. 150psi to 155
Found the fork as diving a bit much on pedally sections in open mode. But I prefer it open to trail which seems to harsh. Will keep playing.
The chain saga is pretty dumb. New chain, oneup gear and cassette arrived before direct mount ring. Couldn't wait, cut new chain to suit 32t but re-used popped pin. went for a few rides, all good, no issues, then mount up 34t without adjusting chain length. first ride it snaps on a climb.
Go to fix it up today and find I've kinked another link about 5 away from the snapped one. Have a few spare links but originally was going to add 1 link to allow a bit More slack on the 34 while in the 42 which was tight under full compression.
When I add the extra link the derailleur when in the 11t looks like this
And in 42t
I suppose I could remove the extra link if it's gonna cause issue having the pulley cage running that flat (thinking chain slapping against itself on the wheels)
