Results 1 to 10 of 14
Thread: Fox 'No Flange' wiper seals
    Sep 2014
    528
    Default Fox 'No Flange' wiper seals
    Hey Guys,
    I notice the latest Fox wiper seals have no flange and I'm concerned the seals can be driven in too far as there is no flange to stop against My usual method is to use a section of PVC pipe; however the outside dia of the pipe is slightly less than the outside dia of the seal. Has anyone had experience fitting these new seals? Any tips you can pass on?
    Why do Fox always have to change things? WTF was wrong with the SKF seals?
    C
    1,997
    I doubt you'll have an issue with overdriving the seal.
    I've always used pipe or old external bottom bracket cups to drive the seals in. Was having a hell of a time with the new no flange seals ! After 20mins of trying various methods I caved and bought the new seal tool the next day. Bang, straight in.
    Senior Member ozzybmx's Avatar
    993
    2 forks to service with the new no-flange seal kits, destroyed one of the new flangeless seals with my usual seal-pusher-inner-tool, managed to get one fork done.
    Had to order a new seal kit the next day... ordered the tool as well. As Creaky says, straight in with the tool !
    Evil Following
    Indy Fab Deluxe 29
    Trek 9.9 Superfly SL
    Pivot Vault CX
    Fat SingleSpeed
    Cervelo R3 Disc
    Sep 2014
    528
    Thanks guys, I will order the pusher inerer tool thingamajig...
    143
    Quote Originally Posted by ChrisJC View Post
    Hey Guys,
    C
    I put a end cap on the PVC tube and cut out the centre and she works well driving the seals in my Pike and 32mm Fox flangeless seals
    Sep 2014
    528
    Quote Originally Posted by mark22 View Post
    I wondered whether that may work. I have an end cap on my PVC pipe to tap the mallet against.
    Dec 2003
    Mount Isa, I eat dust for breakfast.
    179
    They are a fuck to put in. Imagine the tool would be the go, but I was too stingy to pay the $40 or whatever they wanted. I managed to find a Pvc fitting at bunnings that I cut down to fit. Most critical bit is getting it started perfectly square, otherwise they'll never go in. Once they're started you can bash them in pretty easily till the outside diameter of the seal is level with the top of the lowers. Pretty hard to over drive them cause they're that damn tight.
    Have fun.......and a little patience.
    1,069
    The flangeless seals are expensive and look hard to install, so i've just gone with the Racing Bros ones.
    Senior Member Live2DieTrying's Avatar
    Jan 2005
    Upwey, Victoria, Australia
    1,185
    What's the theory behind flangeless seals? Is is to ensure every seal is damaged upon removal and definitely needs replacement?
    It doesn't make much sense... The flange is handy to remove and refit seals that still have some life left in them. Seems the change was really, unnecessary.
    Quote Originally Posted by Robbie Maddison View Post
    You’ve got to push your limits to learn where they actually are.
    Quote Originally Posted by i am sushi View Post
    90% of people in singapore wear glasses while the rest wear contacts
    Senior Member rone's Avatar
    Mar 2005
    VD Land
    3,934
    Quote Originally Posted by Live2DieTrying View Post
    You mean there's some kind of conspiracy???
    Five Five Nine
