Thread: Gunmetal Evil Wreckoning Build Thread
    Jan 2017
    32
    Default Gunmetal Evil Wreckoning Build Thread
    So I've Eventually decided to go through with building an Evil Wreckoning. As I was after a long travel 29er as more of a "Quiver Killer" rather than a XC or DH beast.
    Everything has been ordered and the Frame fork and Seatpost have been Preordered through Stu @ Defcon Cycles ( Aussie Importer)
    So far the spec is:
    Frame: 2017 Evil Wreckoning Size L in Gunmetal
    Rear Shock: Monarch RC3 ( will eventually change to a Topaz)
    Fork: DVO Diamond BOOST axle in Black
    Handlebars: No idea, Will be using Deity blacklabels till I decide
    Stem: No idea, Will be using a Straitline 32mm till I decide on a length
    Headset: FSA x Evil
    Grips: ODI Elite Flow ( Black)
    Saddle: Specialized Henge Comp
    Seatpost: KS LEV 150mmx34.9
    Front Brake: SRAM Guide RSC W/ 200mm Rotor ( Black)
    Rear Brake: SRAM Guide RSC W/ 180mm Rotor ( Black)
    Cranks: Raceface Turbine 170mm w/ gray crank boots
    Chainguide: The built in Evil one
    Chain: Shimano Ultegra 11s
    Pedals: HT X2 silver/gray
    Rear derailleur: Shimano XT M8000 Long Cage
    Rear Shifter: Shimano XTR
    Cassette: Shimano XT 11-46T
    Front Hub: I9 Torch 32h BOOST Black
    Rear Hub: I9 Torch Classic 32h BOOST Black
    Front Rim: Easton ARC 35mm
    Rear Rim: Easton ARC 35mm
    Spokes: Sapim Race Black
    Nipples: Sapim Brass Black
    Tires: F: Minion DHR 2 Widetrail R: Minion SS
    Tubes: Whats a tube? :) Stans Sealant
    Total Weight: No idea - will post when built
    Other: Wolf Tooth Dropper Remote, 32/34t RF cinch chainring
    The frames rougly 2 weeks away but everything else is on its way
    The build kinda got accelerated as Stu gave me a killer deal on the frame, fork and post. Shoutout to Stu and hte great service him and Defcon offer :)
    Ill post some pics when stuff starts arriving :)
    Brisbane, Queensland, Australia, Australia
    716
    Sounds​ awesome! Stu is a top bloke to deal with.
    Sent from my Moto G (4) using Tapatalk
    Senior Member yuley95's Avatar
    Jan 2011
    509
    Two weeks is too long. I'm going to start googling images of similar builds now
    Jan 2017
    32
    Sounds good, ive see one all black one with dvos online
    Jan 2017
    32
    UPDATE
    So things have started arriving, still waiting on the frame to arrive in the country, but the wheels arrived today.
