Results 1 to 10 of 31
Thread: A question for farkers
    1,424
    Default A question for farkers
    Dear farkers,
    saw this pop up the other day.
    Problem:
    You have a bicycle, and your friend is holding it up so that it will not fall over, but he is not applying any pressure to it in any direction. You rotate the crank so that one of the crank arms is facing straight down, and then you tie a length of string around that crank arm. The setup will look something like this:
    With your friend holding the bike up, you pull back on the string. Will the bike move forward, backward, or stay in the same spot?
    Hint: The bike's rear wheel will not skid.
    Senior Member wkkie's Avatar
    Clifton Springs, Vic.
    1,804
    Quick pull - forward, long pull - backwards.
    I'll tells ya! johnny's Avatar
    Mar 2004
    on the dunny
    11,925
    As the arc of the crank moves upward you will stop the bike from moving forward by pulling back on the string. So I'd say that you'd get a little bit of forward movement but very little.
    Respect the Mountain. Ride the Bull. Feel the Flow.
    Successful trades: Nick Z, Rhyno, Naz, RCOH, Parallax, Carlin, Stylinruss, Cave Dweller, Inverted, Teamshore03, Stooge, I-AM-TEH-FASTEST-11, Benana, -Davo, Grover, Drop in Drew, cleeshoy, Bevsta, Daver, hifiandmtb, yogibear, scblack, NoSkidMarks/Crankin. oliosky, dolphinman, binner, iUDEX_nCr, Psimpson7. nickg78
    Senior Member Comic Book Guy's Avatar
    Aug 2006
    Eastern Suburbs of Campbelltown, NSW
    571
    I'll just put this here:
    Kentlyn Trail Map: http://www.openstreetmap.org/?map=19/-34.06667/150.85439#map=15/-34.0592/150.8589
    18,149
    Why do you have string/rope in the forest? What else is in your rode bag? Or do you keep it under the saddle in one of those stupid little bags? Why aren't you and your friend riding?
    Senior Member bear the bear's Avatar
    940
    Quote Originally Posted by johnny View Post
    It depends... the force applied to the string must be sufficient to overcome the inertia of the bike to generate forward momentum. If the force is explosive the system may move forward under its own power (assuming the string has been let go).
    If a steady amount of force is applied, the Jonny's answer is correct as the system is constrained by the ability to apply angular force into the drivetrain.
    Something, something, something
    1,424
    They are imaginary. But valid points nonetheless.
    18,149
    Quote Originally Posted by schred View Post
    Do I need to put some line in my backpack before this afternoon's ride?
    Jul 2015
    70
    It would depend what gear it's in.
    Crank ring / crank length would have to have higher leverage than the wheel size / sprocket size to move forward.
    3,557
    At best you will achieve a small forward movement, at worst nothing. The bike will not be able to move backward because the freehub ratchets will engage and pull the crank against your pull on the string, cancelling it out.
