Thread: Mixed Brake Pads (resin/metallic)
    Member dropotaro's Avatar
    Aug 2009
    geelong
    84
    Default Mixed Brake Pads (resin/metallic)
    So this morning I was procrastinating pretty hard on youtube and came across this vid https://www.youtube.com/watch?v=lb6IC1_6A10 by Alex Chamberlin. In this vid one of his pro tips (Hack 3, 1:42min) is to run a mixture of metallic and resin brake pads in each caliper to get good power and modulation.
    I can see that you would burn through the resin pad way quicker and possibly get uneven wear on your rotor but found it an interesting idea. I was just wondering if anyone has tried this before with good results, or would or the extra maintenance outweigh the benefits?
    Quote Originally Posted by mitchy_ View Post
    i have nothing constructive to add other than i keep reading your name as doctor potato.
    May 2008
    WaitAwhile
    169
    Just run a semi-metallic
    2,693
    The pros probably change brake pads before every race... so I wouldn't say all pro tips apply to us.
    Just run metallic in front and organic out back; best of both worlds.
    3,430
    If you want power and modulation just run metal; they are better than resin on both aspects. Resin give more initial bite, especially when cold, at the expense of modulation.
