Results 1 to 10 of 20
Thread: Lockring different, is my ss kit useless
    Feb 2016
    751
    Default Lockring different, is my ss kit useless
    Hi guys , I have a spare wheel that I intended to turn into a single speed, upon getting the kit it seems like the lockring is of a different kind.
    Is it possible to just take the old one off , do the kit and then use the new one.
    Or do I have a cheap cassette set up that will never work. Photos included
    stink noodle
    17,867
    ...could be time for a confession! Or it is just about a different mounting tool. Thread and diameter are going to be the important things here. Get your pin spanner out and crack that hub open.
    Feb 2016
    751
    Ha ha, funny bugger. Pin spanner. I did intend to whack it with a small file and a big hammer, probably won't because you mentioned the fuckwit thread. May take it to bikeshop and see, fuck it more money
    Senior Member merc-blue's Avatar
    Oct 2008
    Geelong, VIC
    1,983
    your wheel uses a screw on free wheel. its an older style of cassette (often used on cheap bikes..) where the ratchet is part of the cassette not the hub
    you could use a std screw on SS freewheel but the chainline may end up whack
    25,827
    Is it one of the old shitters where the cassette and freehub are one single part?
    edit. Beaten. ^
    stink noodle
    17,867
    Quote Originally Posted by safreek View Post
    Don't you have something that will fit into those 2 holes on your lock ring? I once made one from a paper clip. I doubt that will work in this situation, your cassette looks pretty aged...
    stink noodle
    17,867
    Quote Originally Posted by merc-blue View Post
    edit. Beaten. ^
    So much confessing needed at every turn. Can we send the Reverend to Lismore to help out?
    Senior Member sufferthesinglespeed's Avatar
    Margaret River WA
    231
    That's an old school screw on cassette.
    Need a special tool to unlock it. Not expensive but you can't use the stuff you bought already
    Won't accept a new style cassette. But you can buy SS cassettes to fit.
    My old roadie has the same setup. I bought that roadie in '89.
    Was pretty high end back then.
    Feb 2016
    751
    Thanks for the help guys, looks like I won't bother with that piece of shit, shame cause it's heavy as fuck, that I like
    Any one got a cheap set of modern wheels. Off to the wanted section shortly
    Feb 2016
    751
    Most of them have been banged up for indiscretions so you may need to send one. Not going into a booth with one of them though, that's more dangerous than me and a set of tools
