Results 1 to 10 of 17
Thread: increasing travel on a Rockshox Reba 26" dual air
    Sep 2014
    518
    Default increasing travel on a Rockshox Reba 26" dual air
    Hey all,
    I've only ever worked on Fox forks so this is my first RS experience. My wife has a 2007 Anthem and considering the age, the forks are in great condition. no marks on the stanchions and no play in the bushings. I've removed the air shaft and noticed it has a travel spacer limiting the stroke to 100mm. If I remove it the stroke increases to 120. The stanchions at full extension still allow full contact on the lower bushings so I can't see any issue with increasing the stroke. Just wanted to double check with other RS users before I put it all back together.
    Thanks
    C
    And even worse is the one stupid cunt that doesn't even notice the issues!
    Quote Originally Posted by Ultra Lord View Post
    asked me to do it at stromlo carpark the fuckin twat.
    25,827
    You're doing it right. Welcome to 120's ville. Population gnarr.
    Sep 2014
    518
    Thanks Moorey! I'm just trying to make her bike as capable as possible until she gets a proper trail bike. Pity The Fox forks aren't so simple - I wouldn't mind increasing the travel on my 32 Factory fork out to 120!
    25,827
    Quote Originally Posted by ChrisJC View Post
    Some older fox have a pin to make 80/100 or 100/120. Duck will know if you have serial number.
    3,510
    You overestimate my talents on that one sorry.
    25,827
    Quote Originally Posted by The Duckmeister View Post
    NEVER!
    Google what model they are and a tech manual. I did it with 2 sets of fox recently...with only a little help from Stoo
    3,510
    Just make sure it's actually a travel spacer & not just the top-out bump stop, which is about the same depth as a travel spacer. Rebas can be found in 80-100mm and 100-120 or 130mm variants, so can throw you. The top-out bumper is a rubber cone, a travel spacer will resemble a cotton reel and fit between the bump stop and air piston.
    Sep 2014
    518
    definitely a travel spacer. 15mm high C shaped.
    3,510
    Good-o.
    Sep 2014
    518
    I have a 32 evolution which i upgraded with a Fit 4 damper. The damper will handle the extra travel but the air shaft is non adjustable. I have a feeling my Factory 32 has an adjustable air shaft but not sure the damper will have enough travel. It is an older Fit damper (not fit 4). I'll have to check it out next time i drop the lowers.
    This maybe a silly questionbut are the stanchions and lowers different lengths for different models? I was told by Cyclinic that my forks can't be lengthened. I didnt give specific numbers!
